This code used to control the digital potentiometer
MCP41100 connected to arduino Board
CS >>> D10
SCLK >> D13
DI >>> D11
PA0 TO VCC
PBO TO GND
SHDN >> 9
PW0 TO led with resistor 100ohm .
#include <SPI.h>
byte addressPot0 = 0b00010001; //To define potentiometer use last two BITS 01= POT 0
byte addressPot1 = 0b00010010; //To define potentiometer use last two BITS 10= POT 1
byte addressPot0and1 = 0b00010011; //To define potentiometer use last two BITS 10= POT 0 and 1
byte CS= 10; //Chip control goes to pin 10
byte SHDN = 9; //Chip SHUTDOWN - PIN 9
byte RS = 8; //Chip RESET - PIN 8
void setup()
pinMode (CS, OUTPUT); //CS - When High, sets chip to read the data.
pinMode (SHDN, OUTPUT); //CS - When High, sets chip to read the data.
pinMode (RS, OUTPUT); //CS - When High, sets chip to read the data.
digitalWrite(SHDN, HIGH); //Power ON (HIGH)
digitalWrite(RS, HIGH); //Power NO RESET (LOW)
SPI.begin();
void loop()
PotHighAndLow_mt(addressPot0); //Change POT values on Pot0
PotHighAndLow_mt(addressPot1); //Change POT values on Pot1
PotHighAndLow_mt(addressPot0and1); //Change POT values on both
digitalPotWrite(245, addressPot1);
digitalWrite(SHDN, LOW); //Power OFF (LOW)
delay(5000); //delay for 5 seconds to test current consumption of potentiometer
digitalWrite(RS, LOW); //Power NO RESET (LOW)
delay(100); //delay 100 mls
digitalWrite(RS, HIGH); //Power RESET (HIGH)
delay(10000); //delay 10 sec
void PotHighAndLow_mt(byte address)
/* We have limit from 130 - 255 just for LED test, but for other projects it can be 0-255 */
for (int i = 130; i <= 255; i++)
digitalPotWrite(i,address);
delay(10);
// delay(500);
for (int i = 255; i >= 130; i--)
delay(10);
int digitalPotWrite(byte value, byte address)
digitalWrite(CS, LOW); //Set Chip Active
SPI.transfer(address);
SPI.transfer(value);
digitalWrite(CS, HIGH); //Set Chip Inactive
