Any fast method to checking floating node?
wccheng
Full Member level 5
Hi Folk,
Does C@dence provide any simulation method to check floating node of my circuit? Could you tell me how could I do it?
Thanks
wccheng
erikl
Super Moderator
Staff member
Germany
wccheng said:
Does C(at)dence provide any simulation method to check floating node of my circuit? Could you tell me how could I do it?
wccheng
You don't need to simulate: It's already included in the schematic check, at least by default: You might check the setUp: In a schematic window - in the top menu - click Options -> Check... (or: Check -> Options... ), in the Schematic Check Options menu click Rules Setup ... , then in the Setup Schematic Rules Checks menu Logical options see that Floating Nets creates a warning or an error.
When you click Design -> Check and Save (X) , you should get appropriate warnings resp. errors for floating nets.
wccheng
Full Member level 5
I am thanks for your reply. However, I have another question about floating problem. If I have a circuit because of architecture, it might create floating node in some status. How could I check it in a faster way? Because of large circuit design, I could not check all node one by one.
Thanks
erikl said:
wccheng
erikl
Super Moderator
Staff member
Germany
By LVS .
wccheng
Full Member level 5
LVS just could make sure the connection is same as schematic one. However, it could not solve the problem I mention before.
thanks
wccheng
erikl said:
By LVS .
erikl
Super Moderator
Staff member
Germany
wccheng
Right. If your schematic has no floating nodes and if your LVS matches, you may be sure that your layout doesn't have floating nodes, either. That is - among other items - the LVS is thought for.
wccheng
Full Member level 5
Then, how could I fix this kind of hidden floating node problem?
erikl
Super Moderator
Staff member
Germany
So you got LVS errors and want to know how to fix them? There's no quick procedure for this AFAIK, unless you are experienced with handling the LVS error messages (no. of connections in schematic vs. no. of connections in layout). Otherwise standard methodology is partitioning: divide et impera!
PaloAlto
Full Member level 4
Cádiz, Spain
Hi wccheng,
I think I more or less understand your floating nodes issue, but not completely.
Maybe if you illustrate your question with an example, we can better understand your problem.
