nccu1990
Member level 1
Dear All:
I want to show the dBm unit in the specturm when it connect with directional antenna.
But the AF unit is dBuV/m . The spectrum can only show dBuV unit.
I try to transfer the AF unit to dBi.
Ex: Antenna at 500MHz, the AF=18.707 dBuV/m.
I will use the below formula to transfer the unit.
AF (dB) = 20 * log ( 9.73 / [lambda * sqrt(Go ) ] )
But I don't sure that this transfer is correct or incorrect.
Do you have any suggestion about this issue?
