Antenna Test Measurement + Cross polarisation
aw
Member level 3
Member level 3
Hi everyone,
I am looking for any articles/books/papers on the antenna testing etc :
(I have the paper by Ludwig about cross-polarisation etc)
Anything which explains stuff like aziumth over elevation etc
plz pm or upload to download
thx for your help in advance
aw
antenna polarisation
You may refer to antenna theory by balanis or the book entitled: "antenna measurement"
8) 8) 8) 8)
circular polerisation
of a cross yagi is done using a phasing harnes
2 1/4 wave patchers joined using a T piece then attached
to each set of driven elements
i do this
make 2 1/4 wave patch lead by calculation using velosity factor of .96 then once they are in place using two swr meters an tx at center freq
check the "balance" between each driven element
then adjust the patch leads {radiators etc} for best in both
this is circular polerisation
and gives superiour results too cross polerisation
the trick is too calculate all parts perfect
then you wont need to adjust just check
{using the same type of meter {maker} for both or youll get different results}
polarisation
You may like to read antenna handbook by lee.
:p :p :p
wait me plz.. i'm busy repairing it!!
hi.. i'm so sorry for not sending back... i did't finish uploading my site yet! verysoon you will find the link...
NEC
this is it... full version...
example
if you run this software try this antenna example
thanks to Dr. mohab mangoud...
