AT8052
Newbie level 2
Antenna for 13.56MHz ISM frequency band
Hi, guys. I want to build antenna for 13.56MHz ISM band. I want to ask you if it is possible build it on PCB not bigger than credit card. If yes, which type of antena do you recomend me (mopol, dipol, loop, inverted L, meander)? I need transmition distance up to 25 meters and i want to use transmittion power in range from -20dBm to -10dBm. This antenna is not for passive RFID. It would be very thankful if somebody can help me with it.
