Surrealist
Newbie level 3
cpw ansoft designer
My friends,
I have been having difficulty simulating a coplanar waveguide (CPW) using Ansoft Designer SV. I have created three layers: a 400 um sapphire substrate, a silver ground plane, and a 1600 um of air over the ground plane. I have used the "void" function to carve out two slots in the ground plane layer. I have applied signal to the slots using coupled port excitation. I can run a simulation, but the S-parameters are not believable. Also, it seems to me that the center conductor should be isolated from the ground (which it is not in this simlation).
I have tried to create a void around the entire center conductor. After doing this, I tried to use the "gap source" option in the port properties. However, I cannot get this configuration to mesh. I see an error message that says, "Failed to create special mesh around CPW port 1. Failed to create special mesh around CPW port 2."
Any thoughts?
Surrealist
My friends,
Any thoughts?
Surrealist
