n1cm0c
Full Member level 2
- Joined
- Sep 5, 2006
- Messages
- 146
- Helped
- 27
- Reputation
- 54
- Reaction score
- 2
- Trophy points
- 1,298
- Location
- Santa Maria
- Activity points
- 2,330
jasmin_123 said:Think of t=0K.
jasmin_123 said:ch1k0, zero thermal energy does not mean zero total energy.
halls, T=0 and the infinite frequency do not disturb me, because the problem is
just mathematical abstraction. Mathematical, not physical.
Cheers!
jasmin_123 said:halls, T=0 and the infinite frequency do not disturb me, because the problem is just mathematical abstraction. Mathematical, not physical.
jasmin_123 said:For R-->0, the limit is: a half of the energy is dissipated.Mr.MEB said:and what is the limit when R-->0.
But for an R=0, no energy is dissipated. This is singularity!
jasmin_123 said:"Zero THERMAL energy => no carrier can move".
"If THERMAL energy no zero => carrier can move".
Fudge.
jasmin_123 said:Fudge means nonsense.
ch1k0 said:jasmin_123 said:Fudge means nonsense.
your solution makes no sense ?
or carriers in absolute zero move in your invented solution ?
jasmin_123 said:ch1k0 said:jasmin_123 said:Fudge means nonsense.
They do move as in many superconducting devices.
in the instant the electron starts moving, the temperature is absolute zero no more... it will be 0,0000000000000000001 K if you like, but not 0jasmin_123 said:ch1k0, do you insist that an electron at absolute zero temperature cannot move in an electric field?
halls said:in the instant the electron starts moving, the temperature is absolute zero no more... it will be 0,0000000000000000001 K if you like, but not 0jasmin_123 said:ch1k0, do you insist that an electron at absolute zero temperature cannot move in an electric field?
jasmin_123 said:halls said:in the instant the electron starts moving, the temperature is absolute zero no more... it will be 0,0000000000000000001 K if you like, but not 0jasmin_123 said:ch1k0, do you insist that an electron at absolute zero temperature cannot move in an electric field?
If an electron moves not randomly, for example, it deterministically drifts in an
electric field then its temperature does not increase. It will remain absolute zero.
ch1k0 and halls, ask physicists if you do not believe me. I have asked some of them today,
just to be on the safe side.
Take care!
