Moazza Sultan
Newbie level 5
- Joined
- Apr 9, 2013
- Messages
- 10
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1,281
- Activity points
- 1,334
No, it's not.is it an OPAMP?
To fix the circuit.Why should i do all that ?
Because the circuit you showed doesn't work.reasons?
Maybe you ran the simulation with no input and no feedback. The circuit has a small DC input offset.I try the changes you mention, but Vbe of Q8 becomes 0.44 V
First you need to understand what an opamp is supposed to do. Then you can design a circuit to do that. You also need to understand how transistors work.What are the necessary things to design the OPAMP?
An operational amplifier (op-amp) is a DC-coupled high-gain electronic voltage amplifier with a differential input and, usually, a single-ended output. An op-amp produces an output voltage that is typically hundreds of thousands of times larger than the voltage difference between its input terminals.
