but when i just start to take output after 3rd stage, the output of previous two stages also get badly distorted.. and also OP-AMPs get fused.. i am too worry cause of it
kindly help me
Fleming
OK, I guess your circuit is Analog Filter with one Op-amp and a number of resistor to config sensitivity(In Analog part).
you should to do circuit analysis to find the transfer function then do bold plot analysis to find input voltage maximum, Op amp should operate at voltage supply > input voltage and supply mode of operation that can find in Op amp datasheet.
Well, before any further discussion, why would you like to implement it using MCU? I lost my interest in the project coz it actually is much better in its analog form, also its digital version will need more processing power.
nopeDo you want to apply Microcontroller to be DSP CHIP ? In the past , Someone had impremented in C/C++ language but he use Microprocessor form System on chip(SOC) + ASIC .
But one don't have permitted , finally .
Do you want to apply Microcontroller to be DSP CHIP ? In the past , Someone had implemented in C/C++ language but he use Microprocessor form System on chip(SOC) + ASIC .
You can only give the digital control signals using a MCU. The full circuit implemented using a MCU only? I dont think thats possible.in short i want that a single MCU do what these 6 op apms do which i am trying to implement
