jimmykk
Full Member level 3
- Joined
- Oct 2, 2014
- Messages
- 158
- Helped
- 0
- Reputation
- 0
- Reaction score
- 1
- Trophy points
- 1,298
- Activity points
- 2,865
hi
I was trying to make a ramp voltage using spi dac8311 which will be interfaced with the altera de1 soc board through GPIO bus. thee clock needs to be divided down to 5 mhz for DAC OPERATION and ramp voltagE should be between 0 and 3 V.
In my code down, i wan to increase the value by 3 every time the register is updated and then pass this value serially. But i am not getting my desired result, can anybody help me in where i am doing wrong.
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 LIBRARY IEEE; use ieee.std_logic_1164.all; use ieee.std_logic_unsigned.all; entity dac is port( clock_50 : in std_logic; GPIO_1 : inout std_logic_vector(35 downto 0) ); end dac; architecture arch of dac is type state_type is (init, receiving, sending_1, sending_2, sending_3, sending_4, sending_5, sending_6, sending_7, sending_8, sending_9, sending_10, sending_11, sending_12, sending_13 , sending_14 ,sending_15 ,sending_16 ,sending_17, sending_18); signal present_state : state_type := init; signal data_i : std_logic_vector(13 downto 0) := "00000000000011"; signal clk : std_logic; signal memory_i : std_logic_vector(13 downto 0); signal count : integer range 0 to 9; begin GPIO_1(1) <= clk; process(clock_50) begin if (rising_edge(clock_50)) then if (count = 9) then -- divide 50 Mhz BY 10 TO GET A 5Mhz clock count <= 0; clk <= not clk; else count <= count + 1; end if; end if; end process; process(clock_50) variable int_cnt : integer range 0 to 81; variable sample_count : integer range 0 to 5001; -- loop for generation of increasing control voltage for amplifier begin if (rising_edge(clock_50)) then if (count = 9 and clk ='1') then case present_state is when init=> sample_count := 0; GPIO_1(0) <= '1'; GPIO_1(2) <= '0'; memory_i <= (others => '0'); present_state <= receiving; when receiving => GPIO_1(0) <= '1'; int_cnt := 0; GPIO_1(2) <= '0'; --memory_i <= to_unsigned(i,14); memory_i <= memory_i + data_i; --memory_i <= memory_i+ to_unsigned(i,14); if(sample_count<4900) then present_state <=sending_1; else present_state <= init; end if; when sending_1 => GPIO_1(0) <= '0'; GPIO_1(2) <= '0'; present_state <= sending_2; when sending_2 => GPIO_1(0) <= '0'; GPIO_1(2) <= '0'; present_state <= sending_3; when sending_3 => GPIO_1(0) <= '0'; GPIO_1(2) <= memory_i(13); present_state <= sending_4; when sending_4 => GPIO_1(0) <= '0'; GPIO_1(2) <= memory_i(12); present_state <= sending_5; when sending_5 => GPIO_1(0) <= '0'; GPIO_1(2) <= memory_i(11); present_state <= sending_6; when sending_6 => GPIO_1(0) <= '0'; GPIO_1(2) <= memory_i(10); present_state <= sending_7; when sending_7 => GPIO_1(0) <= '0'; GPIO_1(2) <= memory_i(9); present_state <= sending_8; when sending_8 => GPIO_1(0) <= '0'; GPIO_1(2) <= memory_i(8); present_state <= sending_9; when sending_9 => GPIO_1(0) <= '0'; GPIO_1(2) <= memory_i(7); present_state <= sending_10; when sending_10 => GPIO_1(0) <= '0'; GPIO_1(2) <= memory_i(6); present_state <= sending_11; when sending_11 => GPIO_1(0) <= '0'; GPIO_1(2) <= memory_i(5); present_state <= sending_12; when sending_12 => GPIO_1(0) <= '0'; GPIO_1(2) <= memory_i(4); present_state <= sending_13; when sending_13 => GPIO_1(0) <= '0'; GPIO_1(2) <= memory_i(3); present_state <= sending_14; when sending_14 => GPIO_1(0) <= '0'; GPIO_1(2) <= memory_i(2); present_state <= sending_15; when sending_15 => GPIO_1(0) <= '0'; GPIO_1(2) <= memory_i(1); present_state <= sending_16; when sending_16 => GPIO_1(0) <= '0'; GPIO_1(2) <= memory_i(0); present_state <= sending_17; when sending_17 => GPIO_1(0) <= '1'; GPIO_1(2) <= '0'; present_state <= sending_18; when sending_18 => int_cnt := int_cnt + 1; GPIO_1(0) <= '1'; GPIO_1(2) <= '0'; if (int_cnt = 80) then sample_count := sample_count + 1; present_state <= receiving; else present_state <= sending_18; end if; when others => GPIO_1(0) <= '1'; present_state <= sending_18; end case; end if; end if; end process; end architecture;
