There are chips like CD4016 which is analog switch...If you don't want it then you may need to try some mosfet or transistor combinations... Analog Switches
---------- Post added at 18:41 ---------- Previous post was at 18:39 ----------
In that case you should begin with older databooks from
Intersil / Harris Semi, Siliconix, Data General (if you can find
them). From back before lawyers ran semiconductor
companies and publishing schematic detail was the manly
thing to do.
