analog/mixed system's functional verifcation
qjlsy
Member level 3
How to input analog test vectors for a mixed system's functional verifcation?
Which simulator will be used for such verification?
Thanks a lot!
What is the you EDA tool for Mixed-signal simulation?
The way is not different for different EDA tool.
I am using SpectreVerilog simulator for mixed signal simulation. It works pretty well.
If you've got hspice, you can use vectors as input to it and run simulation.
Of couse the speed is quite slow.
Or you may try nanosim.
