Sillo
Junior Member level 3
I don't want to put my head int a bee's nest but wouldn't it simpler just to have a with spring loaded solenoid with a pin that fit between the brass screws to stop it, and every 11.5 ms you trigger the solenoid with a simple 555 circuit.
---------- Post added at 23:30 ---------- Previous post was at 23:24 ----------
SInce the servo is just there to stop the wheel from turning - correct? so if you just pulse the solenoid it will return fast enough.This will bot work if you want a smooth transition from one pin to the next or you will have to use some resistive washer's or slip ring to get a slow movement from on pin to the next similar to old tape deck door mechanisms.
---------- Post added at 23:30 ---------- Previous post was at 23:30 ----------
Sorry bot NOT
---------- Post added at 23:37 ---------- Previous post was at 23:30 ----------
Remember for you serve to continue to rotate in one direction continuesly you will have to remove the pot inside it otherwise it will rotate just so-far or you will have to reverse it somehow.
Sorry bot NOT
