Hello, I'm working in a company as an Electronics Engineer at R&D department
I want to use Microchip's MCP6V02 Spice model in Altium Designer Summer 2009 program but i have a problem.
When I try it in my project I get error called;
Class Document Source Message Time Date No.
[Warning] Sheet1.SchDoc Compiler Component U1 MCP6V02-E/SN has unused sub-part (2) 12:50:46 25.01.2010 1
[Warning] Sheet1.SchDoc Compiler Net VGB has no driving source (Pin R5-2,Pin R6-2,Pin U1-1) 12:50:46 25.01.2010 2
[Start Output] Output Generator Start Output Generation At 12:50:47 On 25.01.2010 12:50:47 25.01.2010 3
[Output] Output Generator Name: Mixed Sim Type: AdvSimNetlist From: Project [PCB_Project2.PrjPCB] 12:50:47 25.01.2010 4
[Hint] Sheet1.SchDoc AdvSim XU1A - Model found in: C:\Documents and Settings\skesen\Desktop\Simulation_2\MCP6V02.Ckt 12:50:47 25.01.2010 5
[Generated File] Output Generator PCB_Project2.nsx 12:50:47 25.01.2010 6
[Finished Output] Output Generator Finished Output Generation At 12:50:47 On 25.01.2010 12:50:47 25.01.2010 7
[Warning] PCB_Project2 XSpice Unsupported pspice parameter L ignored. 12:50:48 25.01.2010 8
[Warning] PCB_Project2 XSpice Unsupported pspice parameter W ignored. 12:50:48 25.01.2010 9
[Warning] PCB_Project2 XSpice Warning: Resistance is zero. Set to 1k. 12:50:48 25.01.2010 10
[Warning] PCB_Project2 XSpice Warning: Resistance is zero. Set to 1k. 12:50:48 25.01.2010 11
[Warning] PCB_Project2 XSpice Warning: Resistance is zero. Set to 1k. 12:50:48 25.01.2010 12
[Warning] PCB_Project2 XSpice Warning: Resistance is zero. Set to 1k. 12:50:48 25.01.2010 13
[Warning] PCB_Project2 XSpice Warning: Resistance is zero. Set to 1k. 12:50:48 25.01.2010 14
[Warning] PCB_Project2 XSpice Warning: Resistance is zero. Set to 1k. 12:50:48 25.01.2010 15
[Error] PCB_Project2 XSpice Error on line 148: g35\xu1a 33\xu1a 0 table {v(35\xu1a,3v3)} ((-1,-1n)(0,0)(25.0,1n))(26,1)) 12:50:48 25.01.2010 16
[Error] PCB_Project2 XSpice Syntax error. 12:50:48 25.01.2010 17
[Error] PCB_Project2 XSpice Error parsing expression. 12:50:48 25.01.2010 18
[Error] PCB_Project2 XSpice Error on line 171: e97\xu1a 99\xu1a 0 value { v(98\xu1a)*((v(3v3)-v(0))*355m + 288m)} 12:50:48 25.01.2010 19
[Error] PCB_Project2 XSpice Syntax error. 12:50:48 25.01.2010 20
[Error] PCB_Project2 XSpice Error parsing expression. 12:50:48 25.01.2010 21
[Error] PCB_Project2 XSpice Error on line 177: g60\xu1a 0 61\xu1a table {v(3v3,0)} ((0,0)(900m,3.25u)(1.4,260u)(1.5,280u) (3.5,300u)(5.5,325u)(6.5,355u)) 12:50:48 25.01.2010 22
[Error] PCB_Project2 XSpice Syntax error. 12:50:48 25.01.2010 23
[Error] PCB_Project2 XSpice Error parsing expression. 12:50:48 25.01.2010 24
[Fatal Error] PCB_Project2 XSpice Cannot find expression for e97\xu1a. 12:50:48 25.01.2010 25
[Error] PCB_Project2 XSpice doAnalyses: Not found 12:50:48 25.01.2010 26
[Warning] PCB_Project2 XSpice run simulation(s) aborted 12:50:48 25.01.2010 27
