AMWEI Thermistor
Newbie level 1
AMWEI Thermistor, professional manufacturer of PTC & NTC thermistors (THERMally sensitive resistors) and thermistor temperature sensors probe. PTC thermistors application cover over-current & overload protection, telecom, lighting switching, motor starting, temperature sensing & protection, self-regulation heating, linear PTC thermistor, silicon temperature sensor, NTC thermistors application cover power thermistor for inrush current suppressing limiting, NTC thermistor for temperature measurement, indicator, temperature compensation, temperature control, in either radial leaded, axial leaded. Can also make custom made thermistor temperature sensor probe assembly, housed in either stainless steel, copper, plastic, teflon, aluminum, epoxy and heat shrinkable tubing, including air/gas temperature sensors, surface temperature sensors and immersion temperature sensors.
