Ampliifer with a stable gain upto 500khz needed
vinayakdabholkar
goa
Need a opamp with a stable gain upto 500khz to sense the voltage across the sense resistor in a synchronous buck converter
The specs are Vin=12
Vout=1.2V
Iout=12A
Fsw=500Khz
Rsense=10m ohms
Please help
out of idle curiosity, why are you sensing the ripple current and not the smoothed DC current?
Frank
I had thought the ripple current is directly given as a ramp to the pwm comparator, so that a separate ramp wont be generated.
Another thing that i had tried was sensing the inductor DCR current by using a RC in parallel with it and matched the time constants L/DCR to RC so that voltage across DCR is equal to voltage across Capacitor. But could not figure out how to go foward with it to get the average current.
Can any operational amplifier be connected across the sense resistor in a differential amplifier configuration with unity gain to sense the voltage and convert it into a single ended one and then use a resistor to sense the current ?
