Amplifying FM transmitter with transistor
devil6600
Full Member level 5
hi
i have built a fm transmitter, it can transmit to about 50 meters, now i want to increase its range. so i am thinking to remove the antenna and put a 2n2222a transistor and then connect antenna to its collector, will it work?
i know its not legal, but still i want to do this experiment, just once.
thanks
SANDEEP ANAND
INDIA
Re: transistor amplifier
hi
i have built a fm transmitter, it can transmit to about 50 meters, now i want to increase its range. So i am thinking to remove the antenna and put a 2n2222a transistor and then connect antenna to its collector, will it work?
I know its not legal, but still i want to do this experiment, just once.
Thanks
Don't worry in india 100 meters is in legal range to transmit fm signal. Add the circuit diagram ,it will help me to help you better. Regards
