Mar 19, 2018 #1 P paulmdrdo Full Member level 3 Joined Jan 17, 2014 Messages 183 Helped 1 Reputation 2 Reaction score 2 Trophy points 18 Activity points 1,394 what amplifier classes I can combine to achieve both linearity and efficiency aside from class AB amplifier? Thanks, Paul
Mar 19, 2018 #2 KlausST Advanced Member level 7 Joined Apr 17, 2014 Messages 25,176 Helped 4,868 Reputation 9,757 Reaction score 5,541 Trophy points 1,393 Activity points 168,450 Hi, what do you mean with "combine"? Mainly there are class A, B, and D... Theoretically you can combine all of them....it´s a question of effort, circuit and benefit. Klaus
Mar 19, 2018 #3 schmitt trigger Advanced Member level 5 Joined Apr 17, 2013 Messages 2,725 Helped 859 Reputation 1,722 Reaction score 850 Trophy points 1,393 Activity points 18,445 Before class D, there were hybrid classes which were labeled G or H, depending who held the patents. But essentially they were quite similar: the supply voltage would be modulated with the audio waveform.
Mar 19, 2018 #4 crutschow Advanced Member level 6 Joined Feb 22, 2012 Messages 4,460 Helped 999 Reputation 1,996 Reaction score 1,123 Trophy points 1,393 Location Colorado USA Zulu -7 Activity points 25,287 If you are referring to audio power amps, a well-designed Class D amp can have good linearity (low distortion) and high efficiency.
Mar 20, 2018 #5 Audioguru Advanced Member level 7 Joined Jan 19, 2008 Messages 9,457 Helped 2,151 Reputation 4,302 Reaction score 2,008 Trophy points 1,393 Location Toronto area of Canada Activity points 59,721 You can heat your home with a class-A amplifier even when it has no input or output signal.
Mar 20, 2018 #6 P paulmdrdo Full Member level 3 Joined Jan 17, 2014 Messages 183 Helped 1 Reputation 2 Reaction score 2 Trophy points 18 Activity points 1,394 Hello guys! I can't seem to find a good article on the web about the hybrid power amplifiers. Can you point me to a good source that I can read? TIA.
