The Signal range from 100Khz-900Khz is needed to find a suitable frequency for my experiment. The apparatus is a single turn coil, can be increased in turns .
The single has to be fed to the coil , the magmatic field has to be detected by a secondary coil that is the whole experiment. Right now a LC oscillator is is used, and the input signal to the coil [this is the L of the LC oscillator] peaks at around 28-32 Volts. I need to find out what happens if the peak Volts is increased. also different frequency .
Hence this Amplifier setup is though of. The design of Amplifier is not an issue, I need to know if the step up transformer is used in the output stage will it give me a peak voltage i am looking for, using a Class A amplifier with supply of 24 V. and input signal of 12Volt peak [8.5V rms].
The Impedance matching can be handled. the fig is just a rough design idea. Not the actual circuit.
The Big single turn coil represents the type of load that will be connected to the amplifier.
