raman00084
Full Member level 6
can i short 4 and 12 and connect to gnd ? they are enable pins kindly help
Note: This feature currently requires accessing the site using the built-in Safari browser.
It'll work, but,
pin 4 is Enable in positive logic
pin 12 is enable in negative logic
to enable the chip pin 4 has to go to logic 1 (vcc) OR pin 12 has to go to logic 0 (gnd)
to actually disable the chip you need to send pin 4 to GND and pin 12 to VCC
