hi i am using altium designer 10 in windows xp OS service pack 2,grapic adapter intel(R) 82852/82855 GM/GME 64 Mb...m unable 2 switch to 3d error:graphic adapter does not meet directx ........but intel(R) 82852/82855 GM/GME is compatible for direct x https://www.intel.com/support/graphics/intel852gm/sb/CS-009063.htm..what is the problem???
Have you tried to update your graphics driver and do you press 3 on the keyboard, I had an old laptop and still was able to view 3d graphics.
Try this go to prefernces then PCB editor, Then display and make sure the direct x if possible is ticked use flyover zoom in directx is ticked you can aslo test your direct x from there
