Register Log in
Altium spice model simulation
joanna_seczkowska
Newbie level 6
I have imported LT op amp simulation sub circuit model from LTSpice library (.mod) file. I did it by simply changing ext from .mod to ckt.
Altium Accepted this model.
However when it came to simulation it looks Altium does not understand SPICE.
The line which cause error:
ESHD1 88 0 Value={0.5+0.5*TANH(-5*(1.2-V(3,7)))}
I finally figured out that Value in Altium should be replaced by V=( and modified above to the following:
ESHD1 88 0 V=0.5+0.5*TANH(-5*(1.2-V(3,7)))
But now Altium don't understand '*' sign in TANH(-5* ....)
Does anyone has any Hint what is going on?
Robert
Added after 1 hours 4 minutes:
Below lines are from Altium docoment which claims to support below syntax:
Voltage-Controlled Voltage/Current Source
The following general PSpice model forms are supported:
• E<name> <(+) node> <(-) node> VALUE = { <expression> }
Toggle Sidebar
