I'm using the FT232RL from the altium library, but when I want to connect a trace to the pad, I can't get it on the pad. I can only start drawing from the pad to the trace.
And when I do connect them, I get the key symbol on the trace and pad. What does this mean? And how can I fix this?
The key symbol means that the pad is locked, you can double click the pad and un-lock it (the check box is in the properties section) and see if this makes a difference and lets you track into the pad. If not my next guess would be a clerance issue, rules or rouge bit of track on the pad.
I have noticed similar situation several times. While tracing - something crashes and I get error message. After that the last moved net becomes locked.
