Altium Designer with PADS router?
difflvl
altium specctra
Does anyone know how I can use PADS router to route an Altium Designer board?
Is it even possible?
Thanks
gmh
situs router
difflvl
PADS router to route an @ltium Designer board?
You would have to convert @ltium Designer board to
a PADS.PCB file.
Mack
PCB Layout Blog
    difflvl
House_Cat
USA
pads router demo
It would be messy and impractical in my opinion. You would have to use the Mentor translator program to convert your Altium Designer schematic (and/or netlist) and board to PADS. You would then have to do the cleanup that is always required when conversions like this are done. You could then route the board, save the file, and use the Altium Designer Import Wizard to bring the results back into Altium Designer.
You would be better off sticking with one EDA program. If you want an improved router to use with Altium Desginer, you can use either Cadence Specctra, or Electra Router (see https://www.connecteda.com/doc/Autorouting Techniques.pdf ).
    difflvl
difflvl
altium to pads converter
Thanks,
Checked out Electra seems like you can only auto-route and not interactively route.
Ill have a look at specctra. What do you use for auto-routing House_Cat?
Johnson
Advanced Member level 2
altium auto-router
It is question for us, " how much of your design is auto-routing?" Manual routing of big digital design, with many devices and many pin-count, is not a easy job! For a sample 10-layer moderate board, takes more than 3-weeks with hard working. On the other hand, we all know that autorouting will not give an acceptable result.
    difflvl
House_Cat
USA
situs vs specctra
Both Electra and Specctra are autorouters. You do your interactive routing in Altium Designer before and after the autorouter is run. You interactively route and lock critical signal paths, autoroute, then interactively route what the autorouter cannot properly finish.
A human being is the most efficient router ever conceived. Although it takes longer to manually route a board, the results are far superior to anything an autorouter can achieve.
In cases where there is a complex board where the customer prefers speed and there are not too many critical signal paths, I use Specctra. Altium has a direct import/export capability for the Specctra router.
Any autorouter requires carefull setup of routing rules before beginning. It can take a week or so just to set up the router instructions before starting autorouting. It isn't a tool that lets you just mindlessly route a board. The Electra link I listed above is to a document describing how to set up the router for Protel/Altium autorouting.
    difflvl
difflvl
electra altium
Thanks for the responses.
I usually hand route everything anyway. I have a couple larger designs I may be working on and I was interested in a fast efficient auto router for non critical signals.
When I translate the AD PCB benchmark over to PADS, pads can not only route the board with 100% completion in less than 30 mins, but also produces about 1000 less vias with better quality routes. I have yet to finish the benchmark in AD, I get too impatient and stop it, 80% completion in over 2 hours and still going on a 3+ GHz P4.
I tried the electra demo and that router is very fast as well. I can't really say it produced the same quality routes as PADS but it was still a lot faster than AD. Makes me wonder why the Situs router is lacking so much even at their own benchmark.
I guess Ill stick with hand routing until Altium decides to upgrade their router to make it more on par with the competition.
