@ltium Designer PCB Benchmark
Hello, It highly depends on your boards. While I also believe situs is far from perfect, by reducing clearance and track width and increasing space between parts required time decreases almost logarithmically. But god forbidden if you need to route a high voltage, high current >250V complex board which needs considerable clearance and width into a small board. It took about a month for me to manually route such a board, compare it to situs. well it simply fails at very early stages, it can't!
