Altium designer PCB - accidental net unrouting - no way back - a bug?
rehakm
Junior Member level 1
While routing today I probably pressed some unwanted key or so (but don't remember) that caused entire 3V3 net was unrouted. I didn't make any change in schematic or libraries. It's a DC supply bus bar and has many branches and it took me some time to route it. I hoped that undo will take me back but curiously what happened - I pressed undo 30-times (the default depth) but I cannot recover to state when the net was routed! So then I hoped in autosave feature but the latest file in history was from friday :( I'm very disappointed by that so I opened friday backup on second monitor and routed 3V3 net again according backup. I'd like to avoid this in future, could you tell me if it is a regular behavior - and what key I shouldn't touch or is it a bug?
(I use latest updated Altium SE 09 9.4.0.20159
have you tried UNDO?
Have you READ my post? "I pressed undo 30-times (the default depth) but I cannot recover to state when the net was routed!"
