ALTIUM: Anti-PAD definition
maqbool_sid
Member level 3
Karachi, Pakistan
I am using Altium Designer Summer 09.
Kindly let me know, how to define anti-pad for PAD in internal plane.
Description:
I have a SENSE pin (thru-hole PAD) which is has a netname GND, but we don't want to connect it in GND Plane. (It will be connected through a route for some purpose).
For single/multi GND planes, how can I keep this PAD no-connect in GND plane ? we have current option is Placing an ARC around PAD.
Regards,
Maqbool
anilrock87
Full Member level 3
bangalore
Pass one more rule for plane connect style in that you can select no connect for particular net.
Or if you want to be some GND net has to be connected and some has to no connection, make those pad quite different like changing pad x-size to
some other value and then try pass rule using advanced query.
maqbool_sid
Member level 3
Karachi, Pakistan
Thank you Anil
