Altera FPGA SRAM Programming
m_llaa
Full Member level 4
My Love Iran
iord_32direct
Hi
I am working with Altera FPGA, Stratix II EP2S60 with IDT SRAM, but i cant find any documents about sram programming in nios, for example writing 1 word in known address in nios environment.
thanks
iowr_32direct
I find 2 macros, IOWR_32DIRECT() and IORD_32DIRECT()
I can write to my ram by IOWR_32DIRECT() but I cant read from it by IORD_32DIRECT()
IOWR_32DIRECT(BASE,OFFSET,DATA);
IORD_32DIRECT(BASE,OFFSET);
any guide?
thanks
fpga sram
Under Alter installation ,find the standard directory and use the
standard qpf file in SOPC builder and try to access ur SRAM using Nios IDE.
iowr_32direct altera
I'm using memory type Avalon interface for buffers and other memories not register type. Macros IOWR..., IORD... are dedicated for register type inteface. I'm using pointers like " unsigned short* ScopeBufPtr = (unsigned short*) SCOPE_0_SCOPEBUFFER_BASE; ", where base adress SCOPE_0_SCOPEBUFFER_BASE generated by SOPC builder can be found in "system.h" file. Then simply use W = *ScopeBufPtr; etc... Hope this helps. Regards Paul.
    m_llaa
altera macro iowr
Hi BGAman
Thanks for your comment.
Is it any different between IOWR( ) and IORD( ) macros and writing and reading with pointer?
I used those macros but I had problem in reading. if delay between writing and reading increase, I can just read 0xffffffff
