Gentleones,
I'm going to use a dual-readout EDAC card-edge connector part. Since I'm using Allegro, I'm having a bear of a time trying to figure out how to create the daughter board's card edge connector footprint.
Here's what I've done:
First, I've defined a shape for the actual contact finger—it's a SHA file.
Second, I've defined a padstack which uses the SHA file. Single-layer mode is enabled, because the top and bottom fingers on the board need to be on different nets.
Third… there is no third. I don't know where to go from here. I thought I would be able to define a symbol/DRA file with pins on the top and bottom layers of the board, but no dice, or at least I can't figure out how to place a pin on the bottom.
I thought about making a symbol and placing one on the top and then mirroring it to use it on the bottom. The net result would be that the top pin 1 and bottom pin 36 (in this case) would line up since if the top pins were 1-36, left-to-right, the bottom pins would be 36-1, also left-to-right.
Do I really have to make
two symbols which are different for each side of the board?! Or am I missing something really, really obvious?
Frustrated,
Bill
Bill Eccles
www.bill.eccles.net Tolland, CT
No trees were harmed in sending this message.
However, a lot of electrons were terribly
inconvenienced.
