connector footprint
selinozcan
Newbie
I really need your support on something. Although datasheets of some connectors available on internet are available, footprint drawings are not available.
Any chance you can send me the footprints of the 3 connectors mentioned below?
TVP00WCI1135P
TVP00WCI1935P
TVP00WCI1735P
KlausST
Super Moderator
Staff member
The datasheet gives position and diameter of each pad . What else do you need?
Klaus
selinozcan
Newbie
The datasheet does not contain each connector, but all connectors of that series. Therefore, there is no information available for each pad.
KlausST
Super Moderator
Staff member
example from datasheet:
What exactly do you miss?
Klaus
KlausST
Super Moderator
Staff member
If you can´t say what information you miss ... it´s hard to help. I have no crystal ball.
Klaus
selinozcan
Newbie
The type of connectors are as follows. The image you sent and I obtained only represents the position and size of the holes. The rear side and front side of the connector have no dimensions for the footprint.
selinozcan
Newbie
Still unclear what you need.
I tried to ask several times now.
Good luck
The connector consists of different parts: Square flange receptacle jam nut receptacle+straight plug.
I'm asking about footprint dimensions for altium designer of these parts of each connector. I think it was a very clear and clear question from the very beginning and you dont understand.
Thanks
wwfeldman
Advanced Member level 3
i don't understand either
footprints are component information for mounting to a printed wiring board
you need the pin positions, pad sizes for traces and you need an outline to
avoid component crashes.
the square flange layout is for mounting to a chassis, so you know the hole positions and
diameters and is usually found in a different part of connector data sheets
that is, where the shell and mounting information is, instead of where the insert information is
whatever it is you're looking for, its there
FvM
Super Moderator
Staff member
Bochum, Germany
In addition to the PCB footprint data given in the datasheet, Amphenol provides 2D and 3D MCAD data, e.g. .dxf, .step etc. through TraceParts.com
LaTeX Commands Quick-Menu:
