sky_123
Hello,
For small inductors, (up to a couple of hundred nH), is there such a thing as empty coil
formers available (with grooves), to wind air cores?
It would be quite convenient, so that the coil is a bit more rigid than just a wire coil
on its own, and it would also be a bit more consistent if more than one coil was made,
because the grooves would keep the spacing the same.
I notice old radios used to use some waxy gunk to keep the coils in their shape.
Not sure how effective that was!
Coil formers would be quite convenient, especially for tapped inductors.
How do people keep their coils stable (apart from just using heavy gauge wire!) for
air cores?
Thanks!
air cores?
Thanks!
