Ngel
Junior Member level 1
I designed an circuit for my Xbee series 1 module that include an 3.3v regulator and simple logic level converter (ttl to cmos). (see included image please)
I connecting it to a USB to COM converter that i build with AT89C5131, it's working fine with the series 1 with no problems at all.
the problem starts when i replaced the series 1 with series 2 module.
The Xctu program (from digi, program that configure the xbee module) working just fine with the series 1 but when i try it with series 2 it working just for a little bit and the stop (it's ain't get any data from the xbee), i even get the ON led blinking once and then the module ain't responding until reset\power reset.
BTW
series 1 even working even without the capacitors.
someone ever try it or got this problem or have any idea how to fix it?
thanks you all.
BTW
thanks you all.
