ADXL345 Value Problem?
Mucit23
Newbie level 3
Newbie level 3
Hi friends,
I'm using pic16F877 with ADXL345 Accelerometer. I'm running ADXL345 in I2C mode. I can communicate with the sensor.
For example, when I read the registers DEVICE_ID, I'm reading the value 0xe5
When I read the data from the sensor, Every time I get the value 0x00.
This is My ADXL345 library,
// ADXL345  Registers
#define ADXL345_DEVID                   0x00    // R     Device ID
#define ADXL345_THRESH_TAP              0x1D    // R/W   Tap threshold
#define ADXL345_OFSX                    0x1E    // R/W   X-axis offset
#define ADXL345_OFSY                    0x1F    // R/W   Y-axis offset
#define ADXL345_OFSZ                    0x20    // R/W   Z-axis offset
#define ADXL345_DUR                     0x21    // R/W   Tap duration
#define ADXL345_Latent                  0x22    // R/W   Tap latency
#define ADXL345_Window                  0x23    // R/W   Tap window
#define ADXL345_THRESH_ACT              0x24    // R/W   Activity threshold
#define ADXL345_THRESH_INACT            0x25    // R/W   Inactivity threshold
#define ADXL345_TIME_INACT              0x26    // R/W   Inactivity time
#define ADXL345_ACT_INACT_CTL           0x27    // R/W   Axis enable control for activity and inactivity detection
#define ADXL345_THRESH_FF               0x28    // R/W   Free-fall threshold
#define ADXL345_TIME_FF                 0x29    // R/W   Free-fall time
#define ADXL345_TAP_AXES                0x2A    // R/W   Axis control for single tap/double tap
#define ADXL345_ACT_TAP_STATUS          0x2B    // R     Source of single tap/double tap
#define ADXL345_BW_RATE                 0x2C    // R/W   Data Rate and power mode control
#define ADXL345_POWER_CTL               0x2D    // R/W   Power-saving features control
#define ADXL345_INT_ENABLE              0x2E    // R/W   Interrupt enable control
#define ADXL345_INT_MAP                 0x2F    // R/W   Interrupt mapping control
#define ADXL345_INT_SOURCE              0x30    // R     Source of interrupts
#define ADXL345_DATA_FORMAT             0x31    // R/W   Data format control
#define ADXL345_DATAX0                  0x32    // R     X-Axis Data 0
#define ADXL345_DATAX1                  0x33    // R     X-Axis Data 1
#define ADXL345_DATAY0                  0x34    // R     Y-Axis Data 0
#define ADXL345_DATAY1                  0x35    // R     Y-Axis Data 1
#define ADXL345_DATAZ0                  0x36    // R     Z-Axis Data 0
#define ADXL345_DATAZ1                  0x37    // R     Z-Axis Data 1
#define ADXL345_FIFO_CTL                0x38    // R/W   FIFO control
#define ADXL345_FIFO_STATUS             0x39    // R     FIFO status
#define ADXL345_OUTPUTS                 0x32
void adxl345_init(){
         i2c_start();
         i2c_write(0xA6);
         //delay for ack in the slave device
         //Put the ADXL345 into +/- 4G range by writing the value 0x01 to the DATA_FORMAT register.
         i2c_write(ADXL345_DATA_FORMAT);
         i2c_write(0x01);
         i2c_stop();
         delay_ms(10);
         i2c_start();
         i2c_write(0xA6);
         i2c_write(ADXL345_FIFO_CTL);
         i2c_write(0x00);//FIFO inactive
         i2c_stop();
         //Put the ADXL345 into Measurement Mode by writing 0x08 to the POWER_CTL register.
         delay_ms(10);
         i2c_start();
         i2c_write(0xA6);
         i2c_write(ADXL345_BW_RATE);
         i2c_write(0x0c);
         i2c_stop();
         delay_ms(10);
         i2c_start();
         i2c_write(0xA6);
         i2c_write(ADXL345_POWER_CTL);
         i2c_write(0x08); //Measurement mode
         i2c_stop();
int adxl345_read(int add){
         int retval;
         i2c_start();
         i2c_write(0xA6);
         i2c_write(add);
         i2c_start();
         i2c_write(0xA7);
         retval=i2c_read(0);
         i2c_stop();
         return retval;
main code,
#include <16F877A.h>
#device ADC=10
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES NOBROWNOUT               //No brownout reset
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES HS
#use delay(crystal=10000000)
#use I2C(master, sda=PIN_C4, scl=PIN_C3, slow)
#use fast_io(a)
#use fast_io(b)
#use fast_io(c)
#use fast_io(d)
#use fast_io(e)
#include <lcd_driver.c>
#include <ADXL345.c>
int8 accel_data[6];
int16 xaxis=0,yaxis=0,zaxis=0;
unsigned int8 temp=0;
void main()
   set_tris_a(0x00);
   set_tris_b(0x00);
   set_tris_c(0x00);
   set_tris_d(0x00);
   set_tris_e(0x00);
   output_a(0x00);
   output_b(0x00);
   output_c(0x00);
   output_d(0x00);
   output_e(0x00);
   output_float(pin_c3);
   output_float(pin_c4);
   setup_ccp1(CCP_OFF);
   setup_ccp2(CCP_OFF);
   setup_spi(SPI_DISABLED);
   delay_ms(500);
   lcd_init();
   adxl345_init();
   printf(lcd_putc,"\f");
   lcd_gotoxy(1,1);
   temp=adxl345_read(ADXL345_DEVID );
   printf(lcd_putc,"ADXL345_ID=%02X",temp);
   while(TRUE)
     accel_data[0]=adxl345_read(32); //Read X axis(LSB)
     accel_data[1]=adxl345_read(33); //Read X axis(MSB)
     accel_data[2]=adxl345_read(34); //Read Y axis(LSB)
     accel_data[3]=adxl345_read(35); //Read Y axis(MSB)
     accel_data[4]=adxl345_read(36); //Read Z axis(LSB)
     accel_data[5]=adxl345_read(37); //Read Z axis(MSB)
     xaxis=(int16)((accel_data[1]<<8)|accel_data[0]);
     yaxis=(int16)((accel_data[3]<<8)|accel_data[2]);
     zaxis=(int16)((accel_data[5]<<8)|accel_data[4]);
     lcd_gotoxy(1,2);
     printf(lcd_putc,"X%03ld Y%03ld Z%03ld",xaxis, yaxis, zaxis);
     delay_ms(100);
     output_toggle(pin_a0);
Result
What could be the problem?
Thank you for help.
helo....
i am havin same problem in while using pic32mx150f128b with adxl345 .did you get any solution for this dude...
