ukoc
Newbie level 2
hi guys,
im working on altera de0 nano cyclone iv. There is a code written with verilog for adxl 345 sensor. I m trying to write same code with vhdl. I' m using spi 3 wire. After sending data format and power control datas i cant recieve x value
here is my code :
clk_2hz is sclk and sdat is SDIO i used 2 mhz clock for sensor.
thank you and sorry for my bad english :razz:
here is my code :
Code VHDL - [expand] 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 library IEEE; use IEEE.STD_LOGIC_1164.all; -- Uncomment the following library declaration if using -- arithmetic functions with Signed or Unsigned values use IEEE.NUMERIC_STD.all; entity clk_yapan is port ( led:inout std_logic_vector(7 downto 0); clk_50Mhz : in std_logic; clkMhz : inout std_logic; rst : in std_logic; clk_2Hz : out std_logic; clk_4Hz : out std_logic; sclk : out std_logic; G_SENSOR_CS_N: out STD_LOGIC; I2C_SCLK : out STD_LOGIC; I2C_SDAT : inout STD_LOGIC; sdat : inout STD_LOGIC; G_SENSOR_INT : in STD_LOGIC); end clk_yapan ; architecture Behavioral of clk_yapan is component pll is port ( inclk0 : IN STD_LOGIC := '0'; c0 : OUT STD_LOGIC ); END COMponent; alias y1: std_logic is led(0); constant period:integer:=75; CONstant gercekperiod: integer:=1000;--409950 constant clkperiod:integer:=25; signal clkcount :integer range 0 to 50000000 :=0; signal artis,sayac,sayac1,sayac2,kontrol,KONTROL1,artis1:integer:=0; signal pwm_reg,pwm_next:std_logic; signal prescaler, prescaler1 : unsigned(23 downto 0); signal clk_2Hz_i , clk_4Hz_i: std_logic; signal tick,tick1,tick2,tick3:std_logic; signal counter,counter_next,counter1,counter_next1,counter2,counter_next2:integer:=0; signal w : integer range 0 to 127 := 0 ; begin u0: pll port map( inclk0 =>clk_50Mhz, c0 => clkMhz ); gen_clk : process (clk_50Mhz, tick,tick1) begin -- process gen_clk IF TICK = '1' and tick1 = '0' THEN if rising_edge(clk_50Mhz) then -- rising clock edge clk_2Hz_i <= clkMhz; end if; ELSE clk_2Hz_i <= '1'; END IF; end process gen_clk; clk_2Hz <= clk_2Hz_i; i2c_SDAT<=sdat; tick2<= '1' when counter2 < 3 else '0'; tick1<= '1' when counter1 <28 else '0'; counter_next2<= 0 when counter2 = gercekperiod else counter1+1; counter_next1<= 0 when counter1 = gercekperiod else counter1+1; counter_next<= 0 when counter = period else counter+1; tick<= '1' when counter1< 425 else '0'; process(clk_50Mhz,tick) begin if tick='1' then G_SENSOR_CS_N<= '0'; else G_SENSOR_CS_N<= '1'; end if; end process; process(clk_50Mhz) begin if clk_50Mhz='1' and clk_50Mhz'event then counter<=counter_next; counter1<=counter_next1; counter2<= counter_next2; end if; end process; process(tick,clk_50Mhz,CLKMhz) begin IF Tick = '1' AND TICK2 = '0' then if rising_edge(clkMHZ) then CASE W IS --Initial WHEN 0 => sdat <= '0'; w <= 1;--0 --Start WHEN 1 => sdat <= '0'; w <= 2; --1 WHEN 2 => sdat <= '1'; w <= 3; --Slave add WHEN 3 => sdat <= '1'; w <= 4; WHEN 4 => sdat <= '0'; w <= 5; WHEN 5 => sdat <= '0'; w <= 6; WHEN 6 => sdat <='0' ; w <= 7; WHEN 7 => sdat <='1' ; w <= 8; WHEN 8 => sdat <='0' ; w <= 9; WHEN 9 => sdat <='0' ; w <= 10; WHEN 10 => sdat <='0' ; w <= 11; WHEN 11 => sdat <='0' ; w <= 12; WHEN 12 => sdat <='1' ; w <= 13; WHEN 13 => sdat <='0' ; w <= 14; WHEN 14=> sdat <='1' ; w <= 15; WHEN 15 => sdat <='1' ; w <= 16; WHEN 16 => sdat <='0' ; w <= 17; WHEN 17 => sdat <='0' ; w <= 18; WHEN 18 => sdat <='1' ; w <= 19; WHEN 19 => sdat <='0' ; w <= 20; WHEN 20 => sdat <='1' ; w <= 21; WHEN 21 => sdat <='1' ; w <= 22; WHEN 22 => sdat <='0' ; w <= 23; WHEN 23 => sdat <='1' ; w <= 24; WHEN 24 => sdat <='0' ; w <= 25; WHEN 25 => sdat <='0' ; w <= 26; WHEN 26 => sdat <='0' ; w <= 27; WHEN 27 => sdat <='0' ; w <= 28; WHEN 28 => sdat <='1' ; w <= 29; WHEN 29 => sdat <='0' ; w <= 30; WHEN 30 => sdat <='0' ; w <= 31; WHEN 31 => sdat <='0' ; w <= 32; WHEN 32 => sdat <='0' ; w <= 33; WHEN 33 => sdat <='1' ; w <= 34; WHEN 34 => sdat <='0' ; w <= 35; WHEN 35 => sdat <='1' ; w <= 36; WHEN 36 => sdat <='1' ; w <= 37; WHEN 37 => sdat <='0' ; w <= 38; WHEN 38 => sdat <='0' ; w <= 39; WHEN 39 => sdat <='0' ; w <= 40; WHEN 40 => sdat <='0' ; w <= 41; WHEN 41 => sdat <='1' ; w <= 42; WHEN 42 => sdat <='1' ; w <= 43; WHEN 43 => sdat <='0' ; w <= 44; WHEN 44 => sdat <='0' ; w <= 45; WHEN 45 => sdat <='0' ; w <= 46; WHEN 46 => sdat <='0' ; w <= 47; WHEN 47 => sdat <='0' ; w <= 48; WHEN 48 => sdat <='1' ; w <= 49; WHEN 49 => sdat <='1' ; w <= 50; WHEN 50 => sdat <='1' ; w <= 51; WHEN 51 => sdat <='0' ; w <= 52; WHEN 52 => sdat <='1' ; w <= 53; WHEN 53 => sdat <='1' ; w <= 54; WHEN 54 => sdat <='0' ; w <= 55; WHEN 55 => sdat <='0' ; w <= 56; WHEN 56 => sdat <='1' ; w <= 57; WHEN 57 => sdat <='1' ; w <= 58; when 58 => sdat <= null; w<= 59; when others =>w<=58; end case; end if; else sdat <= '1'; end if; end process; end Behavioral;
