linux-dude
Member level 1
I've been tinkering with an idea for a long time; a PC based DVM with isolated test nodes; i.e. each channel is floating. Each channel should be able to do all the usual measurements like A/V AC/DC, Ohm etc. I can't count the number of times i wanted something like this in my lab...
My idea is something like
- Battery (or perhaps small transformers) to power each channel.
- Opto-isolated SPI communication to the main board.
- Isolation voltage good enough for 240V mains testing.
- Main board connects via USB to the PC.
- All settings controlled from the PC, i.e, no buttons on the nodes.
- Several channels, maybe like four to six, should possible.
- Precision should be 1% or better.
- Simplicity wins over saving a few bucks, but it should be reasonable.
- Common parts, easy to source.
- Open source - DIY's should be able to build it.
I have implemented all the digital and firmware parts above in other projects, but the DVM front-end part is new to me, and this is where i want some advices.
I've spent a few hours searching for DVM front-ends, and came up quite empty, except for designs using ICL7135 and the like (**broken link removed**). Though that is a possibility, i would like to explore other paths.
If anyone have some ideas, i would appreciate it much.
Thanks.
Thanks.
