ADS, Rename Component's Name
moreho
Member level 1
Member level 1
i have draw a circuit schematic of microstrip components in agilent ads (2014),
now i want to convert it to stripline.
but the number of components exceed 100, then it is time consuming to do it manually.
i guess it is a simple way such as find and replace command, in sch environment of ADS to do this Idea Automatically.
any Idea...
(for example MLIN wil be SLIN and so on)
thanks.
I think you already know this, but just in case: the easiest command to do this per component is the "Swap component" command, where you can replace the model and keep the existing parameter values.
There is no way to do it automatically for all components on your schematic, except for programming this yourself in AEL (the ADS programming language).
Reactions: moreho
    moreho
that works great.
now i can swap all of one-type component and even their properties in 1-click.
thanks sir.
