bubuta77
Member level 4
Hi
I simulate the PA using model from Infineon. I can't do the load-pull properly because of non- convergence errors. Additionally when i run LSSP simulation the results is the same. When i decrease the input power by 5-10dB from saturation level the problem dissapears. HB for single tone when i make some changes at setup (Krilov method) i can work at saturation levels.
I used to work with AWR and never see such problems. Is it model fault or i do something wrong?
