How can i check dc results from momentum?
what else do you want to see? I cannot understand
Your set-up and simulation method both are essentially wrong.You connected both layout and electrical component to the same PIN.View attachment 149689
When i put the footprints the s parameters are failing
Can you show a screenshot of your transistor pad layout for EM, including the EM pins/ports?
Your use of small EM pieces for pad capacitance is a bit unusal, I think it's not accurate.
The layout of the transistor pads have the dimension given in datasheet. I put the ports in the middle of each pad and i use NONE calibration
It is a first approach to add parasitics in my schematic
The problem is that s parameters does not run!!! (Not how accurate is my model)
Thanks for the reply Volker
So if i create an accurate EM model for the pads, how could I connect the 3 pin electical model in the schematic with the 4 pins EM model, which i create?
