Getting error Using Commandline running ADS simulation including user-defined model
Drss4
Newbie
Hi There!
I am getting this error:
Error detected by hpeesofsim during netlist flattening.
`xxx_1' is an instance of an undefined model `xxx'.
when running a command like this: `hpeesofsim netlist.log` in windows CMD.
The strange part about this is when I run the same simulation in-app, it will not throw this error, this error only occurs when running in the command line. I also discover this error seems only to occur when the simulation includes a user-defined model and will not happen when we only use the ADS model.
I wonder if there is a library of some sort that we need to put our user-defined model library in.
Thank you so much!
Correction from the previous post, apparently it's not using markdown, and the error message got messed up.
The error I'm getting is:
"Error detected by hpeesofsim during netlist flattening.
`xxx_1' is an instance of an undefined model `xxx'. "
the command im using in CMD is:
"hpeesofsim netlist.log"
LaTeX Commands Quick-Menu:
