ADE7756 pin problem - communication pulled down by the IC
~E3016~
Member level 5
ade7756
Hi everyone...
i've a real confusing problem with the ADE7756. whenever i made a communication trough SPI, the DIN (data input to ADE7756) was pulled down by the IC itself, i checked this using the scope, the other pins were OK (SCLK,CS). the logic have to be 1(5V) and 0(0V), but the actual measurement was just 2V - 0V...
i tried use buffer, but the same thing still happen. the DIN from uC is OK now, though.
please help me ...
(i'm using MCS51)
ade7756 input
Hi
Since the SPI pin are not defined as open drain - I think you probably mixed between DO and DI
Just replace between DI and DO - this is a common mistake
All the best
Bobi
Re: ADE7756 pin problem
bobcat1 said:
Hi
All the best
Bobi
thx for caring ...
i have observed that both DIN and DOUT has high impedance as an input or output, and the datasheet doesn't explain that the pin is open drain either. i have also tried to use pull up with 10K ohm. and it seems the IC still pulling it down.
Hi
Upload your schematic
All the best
Bobi
