Adding Libraries in Xilinx ISE (VHDL)?
zeeshanzia84
Full Member level 3
Pakistan / Germany
error:hdlparsers:3317
Hello,
I am trying to use an IP core, for whom a configuration file is provided to me. Now this is a config.vhd file.....
The first two lines of this file are:
library techmap;
use techmap.gencomp.all;
I have ADDED all of the files in a techmap directory (all .vhd files) to my project. Still, at the time of synthesis it keeps showing me the following erorr.
ERROR:HDLParsers:3317 - "E:/Xilinx/leon31/pal/config.vhd" Line 17. Library techmap cannot be found.
ERROR:HDLParsers:3013 - "E:/Xilinx/leon31/pal/config.vhd" Line 18. Library techmap is not declared.
So, can somebody please tell me how I can add this library? What is the extension of the library file?
Thanks a lot in advance.
JFrensch
Newbie level 3
ise library cannot be found
within the ISE
click project/new source...
select "VHDL library"
enter "techmap" as "File name"
click "next"
click "finish"
select the "Libraries Tab" in the "Source" window
right-mouse-click on each file that belongs to your "techmap"-library
select "Move to library"
select "techmap"
last procedure must be done for each vhdl file
Hope, it helps
