ebuddy
Full Member level 3
soc encounter.pdf
How to insert pad ring in SOCE? Is it usually done by editing the netlist manually to include IO cells in the gate level netlist before import it to the Encounter? Is the location of the pads in SOCE also manually adjusted? How about the routing of supply and gnd among IOs? How to add fill io pads and clamp cells?
If some one can provide an example of SOCE script that does the pad ring insertion, then it will be very helpful.
Thanks.
Thanks.
