Feb 18, 2017 #1 O oAwad Full Member level 2 Joined Feb 15, 2017 Messages 136 Helped 0 Reputation 0 Reaction score 0 Trophy points 16 Activity points 1,312 Hello, Can I add a new net in SoC encounter (a modification wire after P&R) without being present in the imported netlist ? Thanks
Feb 19, 2017 #2 T ThisIsNotSam Advanced Member level 5 Joined Apr 6, 2016 Messages 2,549 Helped 397 Reputation 794 Reaction score 464 Trophy points 1,363 Activity points 14,767 oAwad said: Hello, Can I add a new net in SoC encounter (a modification wire after P&R) without being present in the imported netlist ? Thanks Click to expand... Yes. Draw the wire any way you want with the routing tool. Name it anyway you want by changing its properties. No rocket science.
Feb 19, 2017 #3 O oAwad Full Member level 2 Joined Feb 15, 2017 Messages 136 Helped 0 Reputation 0 Reaction score 0 Trophy points 16 Activity points 1,312 Well, I select "Add wire" and try to draw it, but I get an error "open edit route form to input net name". I do so and give an arbitrary name, but then I get another error saying "net name is invalid".
Feb 24, 2017 #4 K kumar_eee Advanced Member level 3 Joined Sep 22, 2004 Messages 814 Helped 139 Reputation 276 Reaction score 113 Trophy points 1,323 Location Bangalore,India Activity points 4,677 addNet is used to add a net for ECO purpose. If you want to route a net manually, first select the net and shift+A ( add wire ).
Mar 5, 2017 #5 O oAwad Full Member level 2 Joined Feb 15, 2017 Messages 136 Helped 0 Reputation 0 Reaction score 0 Trophy points 16 Activity points 1,312 kumar_eee said: addNet is used to add a net for ECO purpose. If you want to route a net manually, first select the net and shift+A ( add wire ). Click to expand... Thank you, if I want to add a new output port to my layout (which is already designed), should I use ECO ? Basically, I want to add a new output port with no routing..no cells..nothing and I will manually route it afterwards. How to do that ?
