Adding a 5 sec delay into my current program
ColonelSanders
Newbie level 2
Newbie level 2
Greetings everyone. I am new to this forum. What I am trying to do is take a program I have already wrote and modify it a bit. First, this is for a PIC16F84A. I have a training board I can program this to but also can use MPLAB spftware to simulate.
Currently, my program code first Lights all LED's for a 0.48 second delay, then it extinguishes all LEDs with a 0.48 delay, then it moves on to the actual main program.
The 0.48 second delay is used later on within the program. What I am trying to do is have the initial LED test to use a 5 second delay instead of a 0.48 second delay, but still utilize the 0.48 second delay for the rest of the program.
To start, I will post my original program code that works correctly with only 0.48 second delay. Next I will post the code where I tried implementing the desired 5 second delay only in the initial LED test.
I would appreciate any advice that anyone could give me on how to accomplish my goal of having a 5 second delay (LEDs on 5 sec, LEDs off five seconds) in the initial LED test.
ORIGINAL (working) PROGRAM CODE BELOW:
		#include <GENERAL.H> ;This is the header file
COUNT1	EQU	0X20			; Counter for the inner loop
COUNT2	EQU	0X21			; Counter for the middle loop
COUNT3	EQU	0X22			; Counter for the outer loop
		__CONFIG	0X3FF6	;This is the control bits for CONFIG register
		ORG		0X0000		;RESET or WDT reset vector
		GOTO	START
		ORG		0X0004		;Regular INT vector
;This is the area where your interrupt service routine goes
		RETFIE
START						;The starting place of the user codes
; The I/O must be set up. Pins 7,8,9,10 (PORTB) and 17,18,1,2 (PORTA)
; All other pins are inputs. This allows both port latches to use the same literal
	CLRF	PORTA			; Ensure both port latches are all 0 before
	CLRF	PORTB			; setting up I/O
	BSF		STATUS,RP0		; Shift to bank 1 to change TRIS registers
	MOVLW	0XF0			; TRISA and TRISB both use F0 to have pins 0 - 3
	MOVWF	TRISA			; as outputs
	MOVWF	TRISB
	MOVLW	0XFE
	MOVWF	OPTION_REG		; The prescales needs to be set to 04 for the
							; watchdog timer to time out 1.15 seconds
	BCF		STATUS,RP0		; Shift to bank 0 for normal operation
	MOVLW	0X0F			; This will illuminate all lights
	MOVWF	PORTA			; when it is loaded in both ports
	MOVWF	PORTB
	CALL	DELAY			; Provides a .48 second delay
	CLRF	PORTA			; This will extenguish all lights
	CLRF	PORTB			; when it is loaded in both ports
SWTEST
	CLRWDT
	BTFSC	PORTB,RB5		; This is the switch for all LEDs being lit
	CALL	ALLIGHTS		; (Switch 3)
	CLRWDT
	BTFSC	PORTB,RB6		; This is the switch for red LEDs beig lit
	CALL	GREENLIGHTS		; (Switch 2)
	CLRWDT
	BTFSC	PORTB,RB7		; This is the switch for the yellow LEDs being lit
	CALL	YELLOWLIGHTS	; (Switch 1)
	MOVLW	0X00			; This will extenguish all lights
	MOVWF	PORTB
	GOTO	SWTEST			; Return to the top of the switch test loop
ALLIGHTS
	MOVLW	0X0F			; This will illuminate all lights on PORTA
	MOVWF	PORTA
	MOVLW	0X00			; and extenguish all on PORTB
	MOVWF	PORTB
	CALL	DELAY
	MOVLW	0X00			; This will extenguish all lights on PORTA
	MOVWF	PORTA
	MOVLW	0X0F			; and illuminate all lights on PORTB
	MOVWF	PORTB
	CALL	DELAY
	RETURN					; Return to the top of the switch test loop
GREENLIGHTS
; If switch 2 is set, only RA1 and RB1 must be illuminated, the delay called, and then
; lit, and the delay called
	MOVLW	0X04			; This will light the green lights only
	MOVWF	PORTA
	MOVLW	0X02
	MOVWF	PORTB
	CALL	DELAY
	MOVLW	0X09			; This will light the red ights only
	MOVWF	PORTA
	MOVLW	0X00
	MOVWF	PORTB
	CALL	DELAY
	RETURN
YELLOWLIGHTS
; If switch 3 is set,RA2, RB0, RB2, RB3 must be turned on, the delay called
; and then RA0 and RA1 turned on, and the delay called again.
	MOVLW	0X02			; This will light the yellow lights only
	MOVWF	PORTA
	MOVLW	0X0D
	MOVWF	PORTB
	CALL	DELAY
	MOVLW	0X09			; This will light the red lights only
	MOVWF	PORTA
	MOVLW	0X00
	MOVWF	PORTB
	CALL	DELAY
DELAY
; This subroutine is a fixed delay loop. It is 2,393,421 clock cycles long, for
; a wait time of .4799 seconds with a 20 MHZ resonator.
	CLRF	COUNT1
	CLRF	COUNT2
	CLRF	COUNT3
	MOVLW	0X7E			; (1)
	MOVWF	COUNT3			; (1)
LOOPOUT
	MOVLW	0X4F			; (1)
	MOVWF	COUNT2			; (1)
LOOPMID
	MOVLW	0X4F			; (1)
	MOVWF	COUNT1			; (1)
LOOPIN
	DECFSZ	COUNT1,F		; (1 of 2)
	GOTO	LOOPIN			; (2)
; This will be executed 29 times
	DECFSZ	COUNT2,F		; (1 of 2)
	GOTO	LOOPMID			; (2)
; This loop will be executed 29 times
	DECFSZ	COUNT3,F		; (1 of 2)
	GOTO	LOOPOUT			; (2)
; This loop will be executed 126 times
	RETURN					; (2)
	END
My Attempt at adding the desired 5 second delay (probably royally screwed it up!):
GOTO   START
RETFIE
	MOVWF   TRISB
	MOVLW    0XFE
	MOVWF   PORTB
	CALL    DELAY5S                ; Provides a 5 second delay
SWTEST
	CLRWDT
	CLRWDT
	CLRWDT
	MOVWF   PORTB
ALLIGHTS
	MOVWF   PORTA
	MOVWF   PORTB
	CALL    DELAY
	MOVWF   PORTA
	MOVWF   PORTB
	CALL    DELAY
GREENLIGHTS
	MOVWF   PORTA
	MOVLW   0X02
	MOVWF   PORTB
	CALL    DELAY
	MOVWF   PORTA
	MOVLW   0X00
	MOVWF   PORTB
	CALL    DELAY
	RETURN
YELLOWLIGHTS
	MOVWF   PORTA
	MOVLW    0X0D
	MOVWF   PORTB
	CALL    DELAY
	MOVWF   PORTA
	MOVLW    0X00
	MOVWF   PORTB
	CALL    DELAY
DELAY
	CLRF    COUNT1
	CLRF    COUNT2
	CLRF    COUNT3
	MOVLW    0X7E                    ; (1)
	MOVWF   COUNT3                   ; (1)
LOOPOUT
	MOVLW    0X4F                    ; (1)
	MOVWF   COUNT2                   ; (1)
LOOPMID
	MOVLW    0X4F                    ; (1)
	MOVWF   COUNT1                   ; (1)
LOOPIN
	GOTO    LOOPIN                   ; (2)
	GOTO    LOOPMID                  ; (2)
	GOTO    LOOPOUT                  ; (2)
	RETURN                           ; (2)
DELAY5S
CLRWDT
	MOVLW	0XE3
	MOVWF	COUNT1
	MOVLW	0X7F
	MOVWF	COUNT2
	MOVLW	0X37
	MOVWF	COUNT3
DELAY5S_0
CLRWDT
	DECFSZ	COUNT1, F
	GOTO	next1
	DECFSZ	COUNT2, F
next1
CLRWDT
	GOTO	next2
	DECFSZ	COUNT3, F
next2
CLRWDT
	GOTO	DELAY5S_0
	RETURN
	END
Actually, I have solved my own problem and feel a bit silly for not realizing this. I do believe that by having the WDT enabled it was being triggered due to my 5 second delay. I took out the WDT altogether and it works fine now. I would, however, be curious to know how to make it work with the WDT enabled. I am assuming I would need to tweak the OPTION_REG setting? Thanks !!
you need to clear the watchdog timer before it times outs and reset the processor
in C there is usually a function call, e.g. PIC18, PIC24, etc
                 ClrWdt();						// clear watchdog timer
there will be a similar instruction in assembly language, e.g.
CLRWDT
Nice piece of coding with plenty of comments added.
As shown below have made a couple of changes to your code to make things clearer.
Looks like you have created your own 'general' .inc file - unusual, but its probably better if your refer to the standard Microchip INC files.
( assume your are using the Assembler within MPLAB and not some third party assembler)
Rather than a meaningless number you can code your Config statement as shown, much clearer to see what parameters are set to.
The Banksel directive is much easier to use than the BSF STATUS ...
While its good to understand how a Delay loop works, it can be a pain working out the exact timings.
Much easier to use this calculator **broken link removed**
	list      p=16F84A            ; list directive to define processor
	#include <p16F84A.inc>        ; processor specific variable definitions
	__CONFIG   _CP_OFF & _WDT_OFF & _PWRTE_ON & _HS_OSC
;     #include <GENERAL.H> ;This is the header file
;  __CONFIG          0X3FF6  ;This is the control bits for CONFIG register
	GOTO   START
	RETFIE
;	BSF      STATUS,RP0            ; Shift to bank 1 to change TRIS registers
	banksel TRISA
	MOVWF   TRISB
	MOVLW    0XFE
;	BCF     STATUS,RP0             ; Shift to bank 0 for normal operation
	banksel	PORTA
As a general rule, if you are using software delays, create a routine for the shortest delay you are using and when you need a longer one, just call it in a loop as many times as necessary. Always include a 'clrwdt' instruction in the innermost loop, it doesn't matter if use it more often than needed, you have already seen the consequences of not using it often enough!
The lack of a 16-bit timer is a pain in that processor, you can create timer delays with the 8-bit one but bigger counters are easier. If you use timers and interrupts to create delays it makes the program far more versatile because it can do other things while waiting for the delay period to finish. It would be worthwile 'upgrading' to a 16F628A or better still a 16F1847 which have more internal features and exactly pin compatible and probably cheaper too.
Brian.
Just make sure your programmer can handle the newer 16F1847.
Also consider the compatible 16F88 which is almost as good and usually in most programmers device files.
