adding 2 binary numbers
johnny78
Full Member level 4
hi Guys
one of the first lessons i've learned when started to learn programming was Numbers
but i forgot how to do this.
00010000
or
00000000
result
00010000
is it right i should use Or function ?
i've tried this with serial monitor to test what im doing but the result isnt what i need
int LedsDisplay = B00000000;
int PowerDisplay = B00010000;
void setup() {
  // put your setup code here, to run once:
  Serial.begin(9600);
void loop() {
  // put your main code here, to run repeatedly:
  Serial.println("Start");
  Serial.println(LedsDisplay);
  delay(1000);
  Serial.println(PowerDisplay);
  delay(1000);
  LedsDisplay =  ((LedsDisplay) || (PowerDisplay));
  Serial.println(LedsDisplay),BIN);
  delay(1000);
  delay(1000);
help me with this please
sorry for my english maybe i couldnt explain what i need exactly or do a useful search
thanks
Johnny
you already used OR function....
I don´t know "what you need".
So, as always, give clear informations:
* what do you expect it to do?
* what does it do instead?
(maybe with examples, drawings...)
OR and ADD are different functions.
use OR when you want to OR
but use ADD when you want to ADD.
example: binary:
001 OR 011 = 011
001 ADD 011 = 100
001 AND 011 = 001
example: binary:
001 OR 011 = 011
001 ADD 011 = 100
001 AND 011 = 001
Hi
so OR is the right function i need but something wrong is going on
my code is giving another results
the result on serial monitor
_____________________
Start
Start
i should get
Start
16
as example of what i need
a = 00001100
b = 00100000
_______________ Result
c =00101100
a = 00010000
b = 00100000
c =00110000
thanks
Johnny
--- Updated ---
thanks Mr
i've found what i need exactly
my fault was using || instead of |
regards
Johnny
to your code:
What compiler and what IDE do you use?
If you get any compiler errors and warnings, please post them.
What worries me:
* "B00000000": it surely depends on compiler, but I know "&b00000000", "0b00000000" ... but no one with a "B" as first letter
It looks like a "logical OR" instead of a bitwise OR.
so shouldn´t it be:
* (LedsDisplay | PowerDisplay);
* or (LedsDisplay OR PowerDisplay);
This I expect to cause a compiler error.
It has one opening bracket, but two closing brackets.
BTW: I recommend to declare your variables explicitely how you want it to be.
instead of "int LedsDisplay ..."
better write "uint8_t LedsDisplay..." ( unsigned 8 bit )
--> so it´s clear that you force it to be an 8 bit variable without a SIGN bit.
"int" can depend on complier and processor and may be an 8 bit, 16 bit, 32 bit ... variable.
Also it´s a good idea to write in the first lines of code for which type of microcontroler the code is written. Some compiler need this, but you are free to write it as comment.
And especially if you post this code in public (forum) ...
    johnny78
to your code:
What worries me:
so shouldn´t it be:
hi
im using Arduino IDE & no i didn't got errors
maybe the compiler corrected it for me
anyway thanks for the valuable informations you've provided was not in mind at all
best regards
Johnny
Interpreting a logic or as bitwise or is not correction, it's a fault.
The stanadard is pretty clear about this
The || operator shall yield 1 if either of its operands compare unequal to 0; otherwise, it yields 0. The result has type int
    johnny78
hi
i was talking about this error which Klaus mentioned about it
& i've used || operator by mistake instead of |
best regards
Johnny
