ADCS7476 problem on programming
satria02
Junior Member level 2
Bandung
Hi....
i want to use ADCS7476 (ADC 12 bits, 1MSPS) to convert analog signal to digital signal to be processed on microcontroller (i use microcontroller AVR ATmega8535), but i get problem on programming of this ADC....
using I2C or SPI....?
i was also browsing on internet, but i can't found the sample program of this ADC (ADCS7476), i look for C programming (AVR-GCC)...
thanks before
best regards,
Satria
Satria you should use the SPI since that the interface that the ADC supports. Look at this link for help with the coding AVR Freaks
panos_papajohn
i want to use two ADCS7476 which was read at the same time, and then be displayed on LCD (i use LCD graphic on this case)
this is my schematics design
and this is my list program...
#include <avr/io.h>
#include <avr/iom8535.h>
#include <stdio.h>
#include "T6963C.h"
#include "graphic.h"
#include <util/delay.h>
#define DD_MISO PD4
#define DD_SCK PD6
#define DDR_SPI DDRD
#define PORT_SPI PORTD
#define DD_CS PD5
#ifndef F_CPU
//define cpu clock speed if not defined
#define F_CPU 16000000
#endif
unsigned char i,coba;
unsigned int data;
char lcd_buffer[30];
char data_buf[20];
void GLCD_start()
GLCD_Initalize(); // Initalize LCD
GLCD_ClearText(); // Clear text area
GLCD_ClearCG(); // Clear character generator area
GLCD_ClearGraphic(); // Clear graphic area
void SPI_MasterInit(void)
// Set MOSI and SCK output, all others input
DDR_SPI = (1<<DD_CS)|(1<<DD_SCK);
// Enable SPI, Master, set clock rate fck/16
SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR0);
char SPI_SlaveReceive(void)
PORT_SPI = (0<<DD_CS);
while(!(SPSR & (1<<SPIF)));
return SPDR;
int main(void)
PORTA = 0xFF;
DDRA = 0xFF;
PORTC = 0xFF;
DDRC = 0xFF;
asm volatile (
"in r30,spsr"
"in r30,spdr"
GLCD_start();
SPI_MasterInit();
i = 1;
coba = 0xAC;
while(i < 5)
GLCD_TextGoTo(0,i);
GLCD_WriteString("rosya satria");
i++;
_delay_ms(10);
sprintf(lcd_buffer,"ROSYA SATRIA FIRDHAUST");
GLCD_TextGoTo(0,6);
GLCD_WriteString(lcd_buffer);
GLCD_Rectangle(1,1,238,126);
data=SPI_SlaveReceive();
sprintf(data_buf," %u", data);
GLCD_TextGoTo(0,9);
GLCD_WriteString(data_buf);
while(1);
return 0;
on this program, i try to access one ADCS7476, but still can't access it...
can you tell me what is the problem of this case?
thanks.
