[SOLVED] adc serial _C# problem
bbgil
Full Member level 2
Hi. guys. got some things here that you might be able to help me out. I am able to get adc going by measuring a voltage divider, able to send it to lcd and get it to the gui i created in c#. Here is the problem. as the adc is updating, so is the gui keeps getting data but its continiuous, example is voltage reading = 3.7. i am getting in gui, 373737373737. Also how to put the dot (.) between the numbers? any suggestion is welcome. I have the code here.
#include <pic.h>		// standard pic header file
#include <stdio.h>
#include <htc.h>
#include	<conio.h>
#include "usart.h"//Adapted from http://electronics-diy.com
#include <string.h>		// string function header file
#include "delay.h"
#include "delay.c"
#include "lcd.h"
#include "lcd.c"//Rs-RD4, EN-RD5, RD0-RD3 -- pin 11 -14 of LCD
// Configuration Fuses
#if defined(_16F877A)
#warning PIC16F877A Selected
	__CONFIG(0x3F61);
#else
#error Unsupported PICmicro MCU Selected
#endif
// Global Variables
#define LED1	RB6		//LED connects to port B
#define LED2	RB7		//LED connects to port B
#define LEDS_8 PORTB
#define LEDS_2 PORTC
void get_adc ();
void get_adc()
//8bit data-type variables
unsigned char x;	//ADC low byte
unsigned char y;	//ADC high byte
unsigned long press,calc,w, z;
unsigned long inter, deci;
	DelayMs (1);
	//Start a2d conversion
	//Set GO bit (ADCON0=ADCON0|1;)
	GODONE=1;
	//wait end-of-conversion (conversion complete)
	while(GODONE==1);
	x=ADRESL; //store low byte
	y=ADRESH;	//store high byte
	w=(256*y+x); //multiply the signal together
					//*256.0 is to get the overall stage
press = w*500/1023 ;
inter =  (press/100)%10;
deci = (press/10)%10 ;
lcd_goto (0x0b);
lcd_putch (inter | 0x30 );
lcd_goto (0x0c);				// move cursor to Row 0 Colum 11
lcd_puts(".");					//display “.” (Decimal point)
lcd_goto (0x0D);
lcd_putch ( deci| 0x30);
lcd_goto (0x0F);
lcd_putch ( 0x56 );// letter V for voltage
if (RCIF) {
	z = (inter |0x30);
	TXREG = z;
TXREG = (0x2E);
calc = (deci|0x30);
TXREG = calc;
DelayMs (100);
RCIF =0;
TXIF = 0;
// Send Message Through USART
void SendMessage(const char Message[ ])
	unsigned char MessageOffset = 0;
	unsigned char temp;
	while ((temp = Message[MessageOffset]) != '\0')	// While not end of string
		if (TXIF)		// Ready to transmit next character?
		TXIF = 0;		// Clear transmitted character empty flag
	TXREG = temp;	// Send Character to transmittion register
	MessageOffset++;	// increment Character Index
// main program
void main()
	// Constant Strings
	const char Greetings[ ] = "\r\nHi, you are now connected !!\r\n";
	const char NewLine[ ] = "\r\n";	// New Line
	char  temp;			// Temporary Storage
	const char Instruction[ ] = "\r\nREADING.... ";
	const char Voltage[ ] = "\r\nVoltage is :\r\n";
unsigned long press, deci, inter;
	init_comms();// Sets up the USART - settings defined in usart.h
	TRISB = 0;;		// Initialize LED tristate
	PORTB = 0;		// LED  nitially off
//	ADFM=1, all i/ps analog, +VREF enabled
	//Configure the functions of the Port bits
	ADCON1=0b10000001;
	//clock/channel select & enable bits
	//controls the operation of the A/D module
	ADCON0=0b11000001;
//TRISC=0b00111111;
TRISA=0xFF;	//inputs
LEDS_8=0xFF;	//clear/switch off LEDS
LEDS_2=0xFF;
lcd_init();
lcd_puts ( "READING" );
DelayMs (100);
lcd_clear();
lcd_puts ( "Voltage = " );
SendMessage(Greetings);		// Send Greeting Message
SendMessage(Instruction);
SendMessage(Voltage);
while (1==1)
get_adc();
