ADC output conversion problem
ecaits
Member level 4
Member level 4
Dear All,
I am facing problem in below code. Please refer below.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
void main()
    int data[4];
    unsigned int b,c,d,z=0,e,i,f,a,x,p=0,g,h,j,k,l,o,q;
    unsigned int v;
    float t=0;
    long long m,n;
    PORTD=0x00;
    PORTC=0x00;
    PORTB=0x00;
    TRISD = 0x00;
        TRISB = 0x00;
        TRISC = 0x00;
    ADC_Init();
    f = ADC_Read(0);
    a = f;
    t=a/6.82;
In above code, I am getting output of ADC say 193 in f and same in variable a.
Now I want to devide a by 6.82 to reduce the range from 0-1023 t0 0.00 to 150.00 to display on LCD. But I am not getting the output as per my expectation. What may the problem or how can i divide the variable a by 6.82???
This is part of the whole program code. I am working on PIC16F877 using Hitech C Compiler.
Add LCD code.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
unsigned char strADCVal[23];
float fAdcVal = 0.0;
void main()
    TRISA = 0x01;
    PORTA = 0x00;
    //ADCON1 register have to be configured
    while(1) {
        fAdcVal = ADC_Read(0) / 6.82;
        //if adc value is 1023 then 1023 / 6.82 = 150 (LM35 max o/p)
        //1023 should represent 150 that is Vref+ should be 1.5V
        FloatToStr(fAdcVal, strADCVal);
        LCD_Out(2,1,strADCVal);
Add LCD code.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
void main()
    TRISA = 0x01;
    PORTA = 0x00;
    while(1) {
But I require LCD output in 150.00 range and I want to keep Vref+ as 5V.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
void main()
    TRISA = 0x01;
    PORTA = 0x00;
    //Configure CMCON here (disable Comparators)
    while(1) {
        fAdcVal = ADC_Read(0) / 2.046;
//5V = 1023
//1.5V = 306.9
//306.9 * x = 150
//x = 0.4887585532746823
//1/x = 2.046
//Temperature = fADCVal / 2.046
//If AD value is 306.9 then 306.9 / 2.046 = 150 (150 degree C)
//If your Vref+ is 5V then your max adc value for 150 deg C will be 306.9 (less resolution)
//If your Vref+ is 1.5V then max adc value for 150 deg C will be 1023 (more resolution)
