ADC input and CMCON0 register
HighTechPower
Member level 5
Hi. I'm designing a board with PIC12F683. The datasheet is attached herewith. I'm little bit confused about CMCON0 register. For comparator yes I have to set some values in 3 LSBs but what about if I use these pins as ADC input. Do I still have to declare the COMCON0 register for that GPIO as analog channel or digital channel i.e. if I declare GPIO as analog in COMCON0 then it will be directly connected to comparator which I don't want to use. The confusion arises due to the reason that ADC is also analog channel but I'm declaring it as digital in the said register.
  • 41211B.pdf
Unless otherwise noted in the accirding sections:
* use the ADC configuration register for ADC things only
* use the Comparator configuration register for comparator things only
In doubt read through code examples and/or application notes given by the chip manufacturer.
