Akhil Mohan
Member level 2
- Joined
- May 13, 2011
- Messages
- 53
- Helped
- 2
- Reputation
- 4
- Reaction score
- 2
- Trophy points
- 1,288
- Activity points
- 1,731
Hello all,
I am trying to use the ADC of 18LF4550 to display the analog voltage levels on an 16x2LCD. My code is compiling giving me an out,
ADC OUT =
0000
This is not varying as I change the pot. (1k pot used, variable to AN2, one leg to supply, and another leg to GND).
Can you help me to identify the mistake in my code (LCD part is working fine, and there is no error there) ?
Thanks in advance,
Akhil
ADC OUT =
0000
#include <p18f4550.h>
#include <delays.h>
#include <htc.h>
#define rs LATCbits.LATC0
#define rw LATCbits.LATC1
#define en LATCbits.LATC2
#define _XTAL_FREQ 20000000
__CONFIG (1, FOSC_HS);
__CONFIG (2, WDTDIS & PWRTEN & BORDIS & LVPDIS);
void lcd_init(void);
void disp(unsigned int);
void commd(unsigned int);
void adc_init();
void readADC(unsigned int);
void adc_conv(unsigned int);
void Delay10KTCYx(unsigned char unit);
void Delay1KTCYx(unsigned char unit);
unsigned char out[20]="ADC OUT=";
unsigned int count = 0;
unsigned int result;
void main(void)
TRISA = 0x04;
LATA = 0x00;
TRISC = 0x00;
LATC = 0x00;
TRISD = 0x00;
LATD = 0x00;
TRISE = 0x00;
LATE = 0x00;
Delay10KTCYx(200);
lcd_init();
while(out[count]!='\0')
disp(out[count]);
count++;
adc_init();
while (1)
readADC(result);
adc_conv(result);// Function to convert the decimal vaule to its corresponding ASCII
Delay1KTCYx (240);
void adc_init()
// configure A/D convertor
ADCON0bits.ADON = 0; // Disable A/D module
ADCON1 = 0x0C;
//Read port AN2
ADCON0bits.CHS0 = 0;
ADCON0bits.CHS1 = 1;
ADCON0bits.CHS2 = 0;
ADCON0bits.CHS3 = 0;
//Set FOSC/32
ADCON2bits.ADCS0 = 0;
ADCON2bits.ADCS1 = 1;
ADCON2bits.ADCS2 = 0;
// Acquisition time (2TAD)
ADCON2bits.ACQT0 = 1;
ADCON2bits.ACQT1 = 0;
ADCON2bits.ACQT2 = 0;
TRISAbits.TRISA2 = 1; // input
ADCON0bits.ADON = 1; //Turn on ADC
void readADC(unsigned int result)
Delay10KTCYx( 5 ); // Delay for 50TCY
ADCON0bits.GO = 1; // Code for starting A/D conversion
while (ADCON0bits.GO!= 0); // Wait until the A/D conversion is over
PORTE = ADRESH;
result = ADRESH;
Delay1KTCYx (240);
void adc_conv(unsigned int result)
unsigned int result_new;
int i = 0;
char position = 0xC0;
for(i=0; i<=3; i++)
result_new = result%10; // To exract the unit position digit
result = result/10;
commd(position);
disp(48 + result_new); // Convert into its corresponding ASCII
position++;
void lcd_init(void)
en = 0;
rs = 0;
rw = 0;
Delay10KTCYx( 10 );
commd(0x33); // Set interface to 8-bit
Delay10KTCYx( 5 );
commd( 0x33 ); // Set interface to 8-bit
Delay10KTCYx( 1 );
Delay10KTCYx( 1 );
commd( 0x28 ); // Set interface to 4-bit
commd( 0x28 ); // Function Set
commd(0x0C); // Display On and Cursor Off
commd(0x01); // Clear display screen
Delay10KTCYx( 5 );
commd(0x06); // Increment cursor
void disp(unsigned int character)
PORTD=character >> 4;
rs = 1;
rw = 0;
en = 1;
en = 0;
PORTD=character & 0x0f;
rs = 1;
rw = 0;
en = 1;
en = 0;
Delay1KTCYx(1);
void commd(unsigned int commd)
PORTD=commd >> 4;
rs = 0;
rw = 0;
en = 1;
en = 0;
PORTD=commd &0x0f;
rs = 0;
rw = 0;
en = 1;
en = 0;
Delay1KTCYx(1);
Thanks in advance,
Akhil
